415
How to access grid row from a control contained in a cell
I am using the method of placing a UltraTextEditor with a RightButton and a Control of a UltraGrid, to simulate a multiselect drop down. This drop down grid contains a column of checkboxes. This multiselect drop down is bound to a column the main ultragrid.
When I click the check box(from within the CellChange event) , I need access to the row that is containing the custom drop down grid. (The main grid) Is this possible?
Note: This also needs to be accessed during the drop down grids InitializeRow method, so checking mainGrid.ActiveRow is not feasible as it is null at this time.
