Does anyone know the reason why ultraChart SaveTo method is throwing ArgumentOutofRangeException?. This method has been working for three months and all of a sudden started throwing this exception. Below is my codeprivate ChartEntity GetChartImage(Infragistics.Win.UltraWinChart.UltraChart ultraChart){//generate chartMemoryStream stream = new MemoryStream();ultraChart.SaveTo(stream, System.Drawing.Imaging.ImageFormat.Png, new Size(ultraChart.Width, ultraChart.Height), new SizeF(1f, 1f));ChartEntity newEntity = new ChartEntity();newEntity.Image = Image.FromStream(stream);return newEntity;}
Well I finally found the solution to the problem and it's the Size paramter. The height was coming in as zero and it was triggering the exception. When the height was set to a number, the exception stopped. It is funny.
Thanks. I tried the new Size but it didn't work. Here is the call stack.
The same code was working before but in a different build.
Regards,Lanre
System.ArgumentOutOfRangeException was unhandled Message="Index was out of range. Must be non-negative and less than the size of the collection.\r\nParameter name: index" Source="mscorlib" ParamName="index" StackTrace: at System.Collections.ArrayList.get_Item(Int32 index) at Infragistics.UltraChart.Resources.Appearance.CompositeLegend.FillSceneGraph(SceneGraph scene, IChartComponent chartComponent, ChartCore core) at Infragistics.UltraChart.Core.Layers.LegendLayer.RedirectToCompositeLegend(LegendAppearance legendApp, SeriesCollection seriesCol, SceneGraph scene) at Infragistics.UltraChart.Core.Layers.IconLegendLayer.FillSceneGraph(SceneGraph scene) at Infragistics.UltraChart.Core.ChartCore.DrawChart() at Infragistics.Win.UltraWinChart.UltraChart.SaveTo(Stream stream, ImageFormat format, Size imageSize, SizeF resolution) at Mda.ClinicStation.Client.Common.UI.Scd.Controls.PerformanceStatus.PSViewControl.GetChartImage(UltraChart ultraChart) at Mda.ClinicStation.Client.Common.UI.Scd.Controls.PerformanceStatus.PSViewControl.SaveChartAndData(PerfStatChart csChart, List`1 list) at Mda.ClinicStation.Client.Common.UI.Scd.Controls.PerformanceStatus.PSViewControl.AddToView(Control csChart, List`1 list) at Mda.ClinicStation.Client.Common.UI.Scd.Controls.PerformanceStatus.PSViewControl.CreateTrendingChart(List`1 selectionList) at Mda.ClinicStation.Client.Common.UI.Scd.Controls.PerformanceStatus.PSViewControl.CreateTrending() at Mda.ClinicStation.Client.Common.UI.Scd.Controls.PerformanceStatus.PSViewControl.btnCreateGraph_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m) at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) at System.Windows.Forms.Application.Run(Form mainForm) at Mda.ClinicStation.Client.ShellContainer.Program.Main(String[] args) in E:\CS\350\Client\Mda.ClinicStation.Client.ShellContainer\Program.cs:line 119 at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args) at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args) at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart()
i'm not entirely sure, but a better argument for the resolution argument (the last one) would be new SizeF(72f, 72f).
if that doesn't fix it, please post the call stack for the exception.
