I require font to be arial across application,Hence the following done using AppStylist:
<styles>
<style role="Base">
<states>
<state name="Normal" fontName="Arial" fontSize="8.25" themedElementAlpha="Transparent" />
At run time, Iam using DrawFiter on UltraButton: Ex:
drawParams.Graphics.DrawString(_pricePips, new Font("Arial", drawParams.Font.SizeInPoints), brush, 10, 40);
Now i want to replace hard coded Arial from above , located in ISL file.
Is there any class where i can read StyleSettings inside code.
The DrawFilter's DrawElement method provides you with AppearanceData which contains all the drawing information that the element will use to draw. So you should be able to check the AppearanceData.Font.Name and use that.
