445
Drag and Drop Functionality within UltraTree
i have drag and drop functionality which works fine within ultratree.  when i  tried to use through form. whenever you select drag and drop a folder or some file in the ultra tree the form appears which has two options, either copy or move. based on the selection, copy or move should happen. how to proceed. help me.....
  • 821
            private void treeView_DragOver(object sender, DragEventArgs e)
                Point newPoint = treeView.PointToClient(Cursor.Position);
                UltraTreeNode nodeAtPoint = treeView.GetNodeFromPoint(newPoint);
                if(nodeAtPoint == null)
                  return;
                if (nodeAtPoint == "whateveryouwanttoCheck")
                    e.Effect = DragDropEffects.Move;
                else            {
                    e.Effect = DragDropEffects.Copy;
    Keep in Mind that this method is called on every mousemove. The ultratree does sadly not support a "UltraTreeNodeDragEnter/DragLeave".
