445
Disable a particular column from grouping and event in UltraWinGrid which gets raised on selection of column header only
how can i disable a particular column in UltraWinGrid from grouping.Also which event is raised when i select only a Column header.I need the event only for the column header.
Thankyou,
M.
  • 469350
    Verified Answer
    You can use the BeforeSelectChange or AfterSelectChange events. These events don't just fire for columns, they will also fire for rows or cells, bt you can check the event args to see what kind of selection took place.
  • 8680
    Each column has an .AllowGroupBy property that you can set to "No".
    I don't know.  Perhaps someone else does.
