315
Using UltraDataSource on collections of objects
I have a snippet of sandbox code I'm trying to make work:
List<Foo> foos = new List<Foo>();
foos.Add(new Foo(1, 1));
foos.Add(
new Foo(2, 2));
//What's the best way to get my Foo objects into the ultraDataSource?
ultraGrid1.DataSource = ultraDataSource1;
I know I can manually add rows to the ultraDataSource but that would require iterating over the collection. Is that the only way to add to an UltraDataSource?
To back up a bit... the larger problem I'm simulating in my sandbox is that Foo has two properties, X and Y. I want a grid with ONLY ONE column, X. I'm assuming that the UltraDataSource is the way to go here. Is that assumption wrong. Should I skin this cat another way?
 [Edit: My code got a little chomped somehow, I just made it readable]
