140
How to specify the column position in the grid to be different from the actual position in the bindingdata?
I have recently started using the infragistics UltraWinGrid. I have a situation as described below.
i have a combobox that specifies what query has to be executed wheneever a user changes the item. the result has to be displayed in the ultrawingrid. The no of columns in the datatable varies based on the selection made in the combobox . for some of the queries i need to display the columns in a perticular order. for eg: if the datatable has col1,col2 and col3 in the order. I have to display this in the ultrawingrid in the order col2,col1 and then col3.
How do i do this at runtime? which property of the grid will allow me to display the column in the order i want? i cannot change the query.
please help.
Thanks & Regards
Casey
  • 155
    Verified Answer
    you set the Header.VisiblePosition property (starts at zero)
     UltraGridColumn col;
    col = TransportationGrid.Grid.Rows.Band.Columns["MovementLoadId"];
    col.Header.VisiblePosition = 0;
    col.Width = 100;
    col = TransportationGrid.Grid.Rows.Band.Columns["MovementTime"];
    col.Header.VisiblePosition = 1;
    col.Width = 75;
    and so on...
