How do I configure on UltraNumericEditor to have leading zeros.
For example: when I configure Mask Input = {double:6.4} if user type 123.45 the value of ultranumericeditor will show like that 000123.4500
Can I configure UltraNumericEditor like above? Because I have many many forms use this control so I don't want to code on every form :(
Any help will be appreciate, :)
Dan
That's a bad news :(
Btw, thanks you a lot, Mike
Hi Dan,
I don't see any way to do that.
Hi Mike,
Thanks a lot for your suggestion. But I already tried it before and it's not my expectation :(
With your suggestion, a negative sign will show at left of prompt char when UltraNumericEditor is in View Mode (lost focus).
But in my case, I want a negative sign will show at left of prompt char in Edit Mode. That mean when user type a negative sign, it will appear at left of prompt char immediately
I hope it will be clear for anyone who wants to help me.
Thanks a lot for any help
Try this:
this.ultraNumericEditor1.NumericType = Infragistics.Win.UltraWinEditors.NumericType.Double; this.ultraNumericEditor1.FormatString = "000000.00"; this.ultraNumericEditor1.MaskInput = "-nnnnnn.nnnn";
In this case, I want the negative to appear at left of number, not after a zero.
I want it appear like that -001234.5600 (at present, the negative always appear after a zero like "00-1234.5600"
That mean, when user type the minus, the UltraNumeric will appear the minus sign at the left (-001234.5600)
Can I configure the UltraNumericEditor to do like that?
Sorry for my bad english, I hope you to understand what I want in this case.
Thanks a lot
