570
Combining ProgressBarInfo and DataSet filling status ?
Hi all !
How can I combine the DataSet filling status with the ProgressBarInfo ?
The progress bar should display the curently loaded number of rows into the DataSet while loading the complete result of a query into the DataSet.
I have tried some code with DataTables event handler for adding new rows
	// Add a TableNewRow event handler.
table.TableNewRow += new
DataTableNewRowEventHandler(Table_NewRow);
but the event will be never raised when filling a table via TableAdapter.
I have also tried event handlers for the TableAdapter with the same result.
Any hint or idea is very welcome !
Thanks in advance !
Kinds regard,
Claus
  • 54937
    This isn't really related to the UltraProgressBar/ProgressBarInfo so you might try posting this question on the ms newsgroups relating to the data access. The TableNewRow event is only fired when a new row is inserted (i.e. using NewRow) but filling is not considered adding a new row - maybe one of the other datatable events could be used instead (e.g. RowChanged).
