570
@Infragistics - UltraStatusBar & Designer miss-behavior
Hi !
When creating a UltraStatusBar with the Designer(VS2005), the designer creates an local instance in the InitializeComponent method(Form1.Designer.cs)
private void InitializeComponent(){
            Infragistics.Win.UltraWinStatusBar.UltraStatusBar theStatusBar;
But the desinger does not create a file global private member variable like
private  Infragistics.Win.UltraWinStatusBar.UltraStatusBar theStatusBar;
 When trying to manually insert this statement the designer will automaticly delete it.
 => accessing the status bar in the form is not possible
 I build a workaround to acessing the status bar like that:
        public UltraStatusBar GetStatusBar() {
            UltraStatusBar theBar = null;
            if (this.Controls.ContainsKey("StatusBar")) {
                Object[ bars = this.Controls.Find("StatusBar", true);
                if (bars.Length == 1) {
                    theBar = (UltraStatusBar)bars[0];
            return theBar;
Kinds regard,
Claus
