I have an UltraExpandableGroupBox whose AutoScroll property of the child UltraExpandableGroupBoxPanel is set to TRUE. I have added a bunch of controls, some of which extend past the right side of the UEGB and thus cause the horizontal scroll bar to appear. This is good.
What isn't so good is that the scrollbar doesn't function in the designer. That is, I can't actually scroll the UEGB in design-mode to access those controls off the right-hand side.
Am I missing something? Thoughts?
Thanks... Steve
Thanks for the info. Will look for a future update.
Steve,
This is something that needs to be done in the UltraGridExpandableGroupBoxPanel's designer, since it basically needs to override GetHitTest and let the VisualStudio designer host know that the control should handle the mouse clicks. I have made this change, through bug# 20952, and have submitted this thread to Developer Support so that you can be notified when the fix is available. You could also probably derive your own panel and designer yourself and override GetHitTest. If you have access to the source code, in the Design assembly the UltraGridRowEditTemplateDesigner basically does the same thing in order to allow the contents to scroll.
-Matt
