I am using HeatMapChart3D to plot my data. I would like to achieve similiar look and feel like Excel. Please refer to the attachment. I would like to know if it is possible to achieve this in Infragistics ultraChart. I have tried to change the ColorModel to Custom Skin and add skin color, it doesn't however change the "surface" color. It only changes the "frame" color. It seems like the HeatMapChart3D color only can be affected by setting the ColorBgin and ColorEnd settings. These two settings are not sufficient in my case since I would like distinct colors for each section just like the one in the attached. Can anyone please recommend a solution or if there is one at all?
Did somebody find a solution of the problem related to the colors in the HeatMapChar3D as adachan8 described?
I also would like to achieve a color look like that.
Thank you
maurizio
i don't think the winchart is capable of this kind of coloring. you can submit a feature request here: http://devcenter.infragistics.com/protected/requestfeature.aspx
