Our software does not support the concept of all-day events, so I'd like to hide the all-day event area at the top of the view. I can't seem to find a property to do this, however. How can this be accomplished?
Bill
It doesn't matter, in release mode that condition won't be asserted, they aren't even compiled into the bits. You will not experience any problem from that whatsoever.
Sorry, I wrote the wrong term in my haste. You are correct that we are seeing an assertion here, not a exception. Either way, however, the behavior is incorrect.
I checked that method and while it probably should not be getting called (the AllowAllDayEvents feature was added after the original release of the control), I did not get an exception but rather a debug assertion. Furthermore, I saw no code in there that would easily explain an exception, and no changes that were tagged with a recent date, so I am not able to expain why you got an exception, nor do I think that updating to the latest service release will solve your problem. If possible post a simple sample demonstrating this exception and we will take a closer look.
Perhaps I spoke too soon... You correctly located the parameter to turn off the all-day event area, but now all clicks in the ScheduleOwnerHeader throw an exception in UltraDayView.InvalidateAllDayEventArea. Is this a known bug? We are using the release version of 2008.3, but we will probably update to the latest hotfix of 2008.3 in thenext couple weeks.
Set UltraDayView.CalendarInfo.AllowAllDayEvents to false
