365
Pre Render Event in ultra win grid
HI,
Is there any pre render event in ultra win grid ????
i want to use the following code
to a win grid.
Private Sub DataGrid1_PreRender(ByVal sender As Object, ByVal e As
System.EventArgs) Handles DataGrid1.PreRender
Dim dgitem As New DataGridItem(0, 0, ListItemType.Header)
Dim mycell As New TableCell()
mycell.ColumnSpan = 2 'Set it to the colspan that you want
mycell.Text = "This is the top level header item spanning two columns!"
dgitem.Cells.Add(mycell)
DataGrid1.Controls(0).Controls.AddAt(0, dgitem)
End Sub
please help me
Thanks & Regards
  • 45049
    The PreRender event is used for ASP.NET controls, not Windows Forms controls such as WinGrid.
    With this in mind, I have two follow-up questions:
    • Are you using WinGrid in a Windows Forms application, or are you instead using WebGrid or WebDataGrid in an ASP.NET application?  I'll need to know this before I can give any more specific advice.
    • What exactly are you attempting to accomplish?  It looks like you're trying to span content horizontally across two cells in the same row.  Is this correct?
