2765
Wingrid - Header Checkbox issue
I am using wingrid’s new feature that allow to check all the rows with the header click. I have noticed one thing that whenever I want to uncheck all the rows, I have to uncheck  header check box twice in order to remove the selection from header however all the rows are getting unchecked with single click. Is this bug or I am missing nay property. Below is the code which I am using in InitilizeLayout () function:
I have also attached sample attachment.
With e.Layout
If .Bands(0).Columns.Exists("Select") Then
.Bands(0).Columns.Remove(
"Select")
End If
.Bands(0).Columns.Add(
"Select", "")
.Bands(0).Columns(
"Select").Style = Infragistics.Win.UltraWinGrid.ColumnStyle.CheckBox
.Bands(0).Columns(
"Select").Header.CheckBoxVisibility = Infragistics.Win.UltraWinGrid.HeaderCheckBoxVisibility.WhenUsingCheckEditor
.Bands(0).Columns(
"Select").Header.CheckBoxAlignment = Infragistics.Win.UltraWinGrid.HeaderCheckBoxAlignment.Center
.Bands(0).Columns(
"Select").Header.CheckBoxSynchronization = Infragistics.Win.UltraWinGrid.HeaderCheckBoxSynchronization.Default
End With
