I want to use UltraDateTime editor in my application. I have given the input mask as {LOC}mm/dd/yy.
It works when the regional settings of your system is US. But if we change the same to UK, the control crashes as soon as we click on the dropdown
I have attached the sample application with this post.
To verify, 1) Run the same in US settings2) Close the application. 3) Go to 'Language and Regional Settings', choose 'English (United Kingdom)'. 4) Run the application again5) Click on the date control
Vince,
Thank you for your prompt response. I will discuss it with my team and go from there.
Thanks again!
Best,
Marshal
Marshal,
vimaljonn said:Is there a work around for this?
vimaljonn said:I am curious to know what causes this error.
Since changing your date masks is likely not a viable option, installing the service release of NetAdvantage for .NET 2009 Volume 1 is the best solution.
I am having similar issues here. We just found out about this crash on our testing server. Is there a work around for this? Also, I am curious to know what causes this error.
Installing the Service release is quite a long process here for certain reasons. That is the reason I am looking for a workaround. Any help would be greatly appreciated as time is scarce for us now.
According to the .csproj file, you're using the volume release version of NetAdvantage for .NET 2009 Volume 1. What you're seeing is an issue that has already been reported to us and fixed, as development issue 16510.
I recommend that you download the latest service release, because this contains a fix for this issue.
If you have a registered key, you can download the service release from the My Keys and Downloads page of our website.
If you're evaluating the toolset, you can submit a support request to ask for a service release download link from Developer Support.
