285
Export pdf in Landscape is not working?
I need my grid to be export to pdf in Landscape mode. Even I open pdf for view also it should be in Landscape mode.
But when I specify as TargetPaperOrientation property to Landscape alsow is not working.
Any luck?
Thanks in Advance.
  • 37774
    Suggested Answer
    I just tried this out with the latest version of 9.1 and it worked correctly for me.  I set the TargetPaperOrientation to Landscape in the designer, then used the following code:
    Report report = new Report();
    ISection section = report.AddSection();
    this.ultraGridDocumentExporter1.Export(this.ultraGrid1, section);
    report.Publish("Test.pdf", FileFormat.PDF);
    I also tried a simpler export:
    this.ultraGridDocumentExporter1.Export(this.ultraGrid1, "Test.pdf", Infragistics.Win.UltraWinGrid.DocumentExport.GridExportFileFormat.PDF);
    This may have been an issue that had already been addressed, so you should ensure that you have the latest service release.
    -Matt
