180
UltraComboEditor and List<T> as DataSource
I created a small helper class:
    public class ComboHelper
        public int ValueMember;
        public string DisplayMember;
I want to create a List<ComboHelper> and bind that to a UltraComboEditor control:
List<ComboHelper> comboDataSource = new List<ComboHelper>();
ComboHelper comboHelper = new ComboHelper { ValueMember = 1, DisplayMember = "ID" };
comboDataSource.Add(comboHelper);
comboHelper = new ComboHelper { ValueMember = 2, DisplayMember = "Collateral" };
cmbFilter.DataSource = comboDataSource;
cmbFilter.DisplayMember = "DisplayMember";
cmbFilter.ValueMember = "ValueMember";
I run the app and nothing shows in the combo box.  What am I missing? [I know it's something simple...still trying to get the hang of these controls]
  • 45049
    Verified Answer
    The .NET BindingManager will expose public properties, but not public fields.
    If you're using a .NET 3.5 application (and it looks like you are from your other sample code), change your class definition as follows:
            public int ValueMember { get; set; };
            public string DisplayMember { get; set; };
    If you're using .NET 2.0, you'll need to make these private fields, and then create public properties that get and set those fields.
