I'm having a problem when "entering" values of type Double in a cell.
First of all, my grid is bound to a datatable.
This datatable contains mainly double values.
I'm living in Belgium, so our decimal separator is a comma "," (CultureInfo = "nl-BE")
All values are shown correctly in the grid. So far, so good.
But when editing the decimal values in the grid, and when pressing the "."-button on the numeric keypad, also a point "." is shown in the cell.
"Johnny, this is normal" ... should be a normal reaction from your side ...
But, as an example, when pressing the same button in Windows Calculator, a comma "," is shown...
Surprising, no ... ?
So, my "users" are expecting the "Windows decimal separator" (in our case , a comma) when entering values in a wingrid.
Any idea how to solve this in a smooth way ?
Thanks in advance for your answer,
Grtz,
Problem solved !!
Sample Code:
Dim SalCol As UltraGridColumn = Me.UltraGrid1.DisplayLayout.Bands(0).Columns("Salary")
' Set the Format and FormatInfo properties. ' You don't have to set both. You can set one or the other or both. ' Play with it, and have fun !
SalCol.Format = "##.###" SalCol.CellAppearance.TextHAlign = HAlign.Right SalCol.PromptChar = "" SalCol.Style = ColumnStyle.Double SalCol.FormatInfo = System.Globalization.CultureInfo.CurrentCulture
