230
Child band with ViewStyle vertical.
I have 2 bands, one parent and second child with view style (one under the other) so vertical, but it seems that the first column of parent band is alligned with first column of the child band which makes first column of parent band little wider because child band doesn't start at the same position (localiton.X ) as parent.
Is there any way to skip the alignment of the child with parent bands, or to show child right below (not little to the right) of parent band?
Please advise, I really appreciate your help.
Thank you,
Igor
  • 37774
     Igor,
    Take a look at the Indentation property of the child band.  If I understand your question correctly, you might want to do something like:
    private void ultraGrid1_InitializeLayout(object sender, Infragistics.Win.UltraWinGrid.InitializeLayoutEventArgs e)
        e.Layout.Bands[1].Indentation = 0;
    -Matt
