335
How to show multiple appointments in a single window of UltraDesktopAlert ?
Suppose, there are 5 appoinments are due for today. If a single appoinment is displayed by the
 UltraDesktopAlert window, then all total 5 alert windows will be displayed one after the other. And this is
very annoying.
So, how can i show all the 5 appointments in a single alert window ?
Thanks in advance,
Panna
  • 69832
    Suggested Answer
    I believe this concept is demonstrated in the 'Appointment Reminder' sample. If you want to display multiple appointments in an alert you could use a Timer that ticks (for example) every 5 seconds. Instead of displaying the alerts in response to the BeforeDisplayReminderDialog event, you could add the appointments for which that event is fired to a list, and then in the Timer's Tick event handler, display the alert for whatever appointment reminders came due since the last time the timer was checked.
