Hi, There
I have a question regarding the AppStyling and UltraNumericEditor. When I use a default AppStyling for a UltraNumericEditor, the text field displays a disabled 0 when the focus is first entered into the box, either by mouse click or tab key entry. This happens regardless of the value the editor contains. If I click inside the editor text box, the correct value displays when left button is down, but returns to 0 when left button is up. If I use the arrow keys to move around, the correct value starts to show. This only happens when I have AppStyling applied to the editor box, if I disable AppStyling, the Editor box worked properly.
Any suggestion as on what properly I can manuveur in style library to correct this problem?
Thanks in advance.
Richard Zhu
Hi Richard,
I can't see any reason why AppStyling should have any effect on the value in an UltraNumericEditor. AppStylng only controls appearance-related settings.
If you can provide a small sample project demonstrating this behavior, I will be happy to check it out for you.
