Is it possible to disable certain dates in the DropDownCalendar (ie, Christmas, Easter)? Also, is it possible to set it up to only allow users to select certain days of the week (ie, weekends)?
The dropdown calendar you see in the grid by default for DateTime fields is the inbox MonthCalendar control, and as far as I know, it doesn't have the ability to disable any dates.
What you could do, though, is use the UltraCalendarCombo control, instead. What you would do is place an UltraCalendarCombo control on the form with the grid and hook it up to an UltraCalendarInfo object. The UltraCalendarInfo lets you disable dates. Then you set the EditorControl property of the grid column to the UltraCalendarCombo for any DateTime fields.
