250
is grid.Row.DataChanged still working ?
I have an datatable, bound to an UltraWingrid.
The idea is to allow the user to edit all cells he wants in the UltraWingrid.
Once he pressed an "update" button, the modifications will be written to the database.
I was hoping I could use following code (but it doesn't seem to work)
pseudocode ...
for each myrow in ugrid.rows
  select case myrow.datachanged
    case datachanged.added
      'add record to the database
    case datachanged.deleted
      'delete record from the database
   end select
next
I found this sample code at http://devcenter.infragistics.com/Support/KnowledgeBaseArticle.aspx?ArticleID=8272, but it doesn't seem to work...
whatever "changes" the user makes, datachanged is always "false"
thanks in advance for your help
Grtz,
Johnny
