415
Node images aren't appearing
Display a menu tree of an applications menu:
 Parent node images are set like:
node.Override.ExpandedNodeAppearance.Image = Properties.Resources.smallClosedFolder;
node.Override.NodeAppearance.Image = Properties.Resources.smallClosedFolder;
Leaf nodes are set like:
node.LeftImages.Add(Properties.Resources.User2);
 Neither of the images show up in the tree, but strangely enough it looks like space has been alloted for them in the control.
Any ideas?
  • 69832
    Most likely you are assigning a System.Drawing.Icon to the Image property, which is not supported. Convert the icon to a bitmap (see Icon.ToBitmap method) and don't forget to dispose of any bitmaps you create.
