At the samples that comes with Infragistics, there is one called "AppointmentDialog2007 CS" at folder:
C:\Documents and Settings\All Users\Documents\Infragistics\NetAdvantage for .NET 2007 Vol. 2 CLR 2.0\Samples\WinForms\WinSchedule\CS\AppointmentDialog2007 CS
Inside the form frmAppointmentDialog2007.cs there is a method called "VerifyAppointmentStatus()", within it, the line:
this.lblStatus.Text = this.Recurrence.Description;
returns an description in english, but I wish to translate that. An example would be:
""Occurs every tuesday effective 9/7/2009 from 6:19 to 6:49."
"this.Recurrence" is an object of the class Infragistics.Win.UltraWinSchedule.AppointmentRecurrence.
But I looked at :http://help.infragistics.com/Help/NetAdvantage/NET/2008.2/CLR2.0/html/WinSchedule_Resource_Strings.html
and there is no such string to translate.
Please, how can I translate that?
There is no clear-cut way to do that, which is why MS Outlook doesn't support it either. The information you need is available via public properties, so if you are familiar with the grammatical structure of a given language you can build the strings; for example:
"Occurs every {PatternDaysOfWeek} effective {RangeStartDate} from {OccurrenceStartTime} to {OccurrenceStartTime + OccurrenceDuration}
There is no formulaic conversion between multi-word phrases in different languages, that is, the linguistic rules vary such that the order in which verbs and nouns appear can be arbitrarily different in each language. Because of this, it is impossible to provide localizable strings for recurrence descriptions.
