2387
Changing the editor in one cell of a tree
As I have stated before, I am working on making an property grid that is editable.  I am using the PROPERTYGRID CS as the foundation for my control.  I am struggleing because the "Embeddable Editors Overview" documentation seems to leave a lot of holes.  My current issue is how to replace/change the editor in once particular cell to the CheckEditor.
Attached is a modified version of the PROPERTYGRID CS project.  I changed out the object being displayed in favor of a simple data class with a lot of strings and one boolean.  I added a conditional check to see if the value of the property was a boolean, if true the cell's editor is set to a new CheckEditor:
if (propertyValue is System.Boolean)
    node.Cells[colValue].Editor = new CheckEditor();
The CheckEditor does not seem to be editable event though all the other string values are editable.  What needs to happen to make this editor interact correctly?
This is only a step in understanding how I can implement a custom editor for a property, along the lines of Microsoft's UITypeEditor.  We discussed this a bit in this thread, but I think it was a bit too early in my knowledge of the TreeControl. I don't understand how to connect the UltraTextEditor/EditorWithText to display my custom dialog.  I am assuming/hoping that this will continue to be done via Attribute-oriented programming.
Sam
PROPERTYGRID_CS_CustomDataObj.zip
