95
TopNode property doesn’t work properly in June SR 2029.
Normal 0 false 21 false false false DE X-NONE X-NONE
We have switched to Infragistics 9.1. SR 2029 because of some Excel issues fixed in the last service releases compared to the original release.
However, I have noticed that setting TopNode stopped working properly after update.
Although the scroll bar moves to the correct position, the first node of the tree is displayed on the top instead of the one set in the TopNode property. Pressing the keyboard down key displays correct node on the top again.
Is there any workaround for this issue?
  • 69832
    Verified Answer
    That is a bug that has been addressed; you should log an incident with Developer Support so that you receive a notification when the fix becomes available.
