135
Check/Uncheck items into ultracombo
Hi
I've an ultracombo filled by a dataset which contains some fields with boolean values.
I need to modify my control in order to permit to check/uncheck some rows. I've tried to keep the control dropped down -with different methods : Show, ToggleDropdown, Refresh,...- when I select a row (RowSelected Event) to change my boolean value and refresh the value list, but it doesn't work.
Do you know a way to do that? Or does it exists an easier way to make an checkable ultracombo?
Thanks in advance.
