5520
designer problem
I am upgrading my projects to the version9.1.
the projects are being upgraded successfully, and when i build it's working fine.
My problem is when i try to go to the designer of the form, i am getting the following error many times.
Object of type 'Infragistics.Win.Appearance' cannot be converted to type 'Infragistics.Win.AppearanceBase'.
Hide
at System.ComponentModel.ReflectPropertyDescriptor.SetValue(Object component, Object value)
at System.ComponentModel.Design.Serialization.CodeDomSerializerBase.DeserializeAssignStatement(IDesignerSerializationManager manager, CodeAssignStatement statement)
at System.ComponentModel.Design.Serialization.CodeDomSerializerBase.DeserializeStatement(IDesignerSerializationManager manager, CodeStatement statement)
i checked the licence and i found that it's referencing to the version 5.3 (which is also installed on my pc)
is there a way to enforce the use of version 9.1?
ps: i already had this problem when i was using version 8.1 also. i always had to close the project after debugging and then reopening it.
