340
How to update a listview properly from another thread
Good Morning Guys-
I'm just learning C# so please bare with me! I have a winlistview on a tab page that I am populating with a couple hundred (sometimes more) entries. I populate this winlistview when the form loads. Since it takes a bit to search the files and populate that listview, I decided to start a thread to do the work in the background, so the user can watch as the new entries appear.
It doesn't work right. I get "random" errors from the winlistview as it is being populated. Now there are two listviews that are being updated on the main page and its completely random as to which one throws an error and causes the program to crash. The errors also are random. On one launch it complains about one thing, on another launch it'll throw an exception about something else. I am thinking that I am not doing something properly with the threading.
I'm wondering if anyone could point me in the right direction as to what I need to do in order to fire off another thread and have these winlistviews updated "in the background" as the end user watches.
Here's what I've tried (with no success)
On the On Load event, creating a new thread and myThread.Start()'ing that thread. This usually really upsets the apple cart, even the ultralabels will throw errors. So I read that you cannot update the UI from threads, you have to use delegates.
So what I've done is on the load event, create a new thread, call that thread. The thread gets called, and it creates a delegate with the method that populates the winlistview, like this:
SimpleDelegate myDelegate = new SimpleDelegate(PopulateListView);
myDelegate();
That does not seem to work for the winlistview either (but the labels now never throw errors). If I use this procedure for a windows listview control, it works fine and updates and never crashes.
So long story short is could someone point me in the right direction for adding items to an ultra winlistview from another thread while the main application is still doing its thing accepting user input and whatnot?
Thanks!!
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
   at Infragistics.Win.UIElement.VerifyChildElements(ControlUIElementBase controlElement, Boolean recursive)
