I found a bug in the wingrid, steps:
1-group by any column (ViewStyleBand=OutlookGroupBy)
2-add any summary to any column
3-band.RowLayoutStyle <> None
4-Export to excel ...
Dim ugrdExcelExporter As New Infragistics.Win.UltraWinGrid.ExcelExport.UltraGridExcelExporter
ugrdExcelExporter.export(grid,filename) <--- KEY NOT FOUND EXCEPTION RAISES
Could you reproduce it?
EDIT: if i set band.RowLayoutStyle=none everything works fine
if i remove all the summaries then it's ok
if i have no columns in group by mode then it's ok too.
This has been fixed internally, so I'm pretty sure it will be in the next service release which is scheduled for release December 20th.
Note that there are no more service release for v9.2, so this will be fixed in v10.1 and up.
I can confirm this issue with v10.3.
Any ideas when this will be fixed or if there is a proper workaround?
Was there any solution? I have the same problem when I try to export data from ultragrid using ultragridexcelexporter.
I have catched the exception:
---------------------------Error al exportar---------------------------Key not found
Parameter name: key
Infragistics2.Shared.v9.2---------------------------Aceptar ---------------------------
Thanks in advance,
Nicolás.-
I tried this out and I was able to duplicate the exception. I am attaching my sample project here and I am going to forward this thread over to Infragistics Developer Support so they can get it corrected.
