460
Prevent first Item in list from becoming active
I've created a listbox component which inherits from UltraListView (set with listbox properties).
In my class I've overrided many events such as ItemSelectionChanging, ItemCheckStateChanging etc.. in order to achieve my goals.
However I have a problem, and let's take this simple example: when a new Item is active, which means I've clicked on it, I change his color and modify its checkstate.
When my listbox gets focus and when I click on an item, the first Item of the list is processed too, because it seems to be active since the beginning my listbox has focus...After that there is no other problem of this kind, this just happens for the first selection!
Any idea to prevent the first Item of the listview from being Active ?
Or any idea of the problem if I'm wrong ?
