Hello all,
the windows forms application runs on Windows XP with Infragistics v. 8.1 (HotFix installed)
If the window display DPI setting sets lower (e.g. 75%) or higher (120 dpi),
then button and textbox of the application lost borders or frames...
very strange, any suggestions?
Thanks in advance.
I beleive that Forms in DotNet are set up to scale based on the system font by default. This has nothing to do with the Infragistics controls, it's just that way DotNet forms work in order to provide device independence.
So you probably need to check out Microsoft's documentation and best practices for how to set up your form so that things don't get overlapped. Check out the form's ScaleMode property as a good starting point.
