250
Is it possible to move the push pin icon to fix a header in a grid?
I have a number of columns where i want to right align the column header text.
So i can right align the text but the icon for fixing the column still appears on the far right.
When i have my text right aligned i hwant to be able to left align the pushpin button.
Is this possible?
  • 469350
    Suggested Answer
    Hi Richard,
    There's no property for this, but it could be done using a CreationFilter. This is actually a pretty simple CreationFilter, since all you really have to do are swap the X values of the element rects.
    Here's a quick sample I threw together:
        public class FixedHeaderButtonOnLeft_CreationFilter : IUIElementCreationFilter
            #region IUIElementCreationFilter Members
            void IUIElementCreationFilter.AfterCreateChildElements(UIElement parent)
                // See if the parent is a HeaderUIElement
                HeaderUIElement headerElement = parent as HeaderUIElement;
                if (headerElement == null)
                    return;
                // Get the TextUIElement and the FixedHeaderIndicatorUIElement inside it.
                TextUIElement textElement = headerElement.GetDescendant(typeof(TextUIElement)) as TextUIElement;
                FixedHeaderIndicatorUIElement fixedHeaderIndicatorElement = headerElement.GetDescendant(typeof(FixedHeaderIndicatorUIElement)) as FixedHeaderIndicatorUIElement;
                // If the FixedHeaderIndicatorUIElement is null, then do nothing.
                if (fixedHeaderIndicatorElement == null)
                    return;
                // Change the X position of the rect of the FixedHeaderIndicatorUIElement so it's
                // position on the far left of the header inside the borders.
                fixedHeaderIndicatorElement.Rect = new Rectangle(
                    parent.RectInsideBorders.X,
                    fixedHeaderIndicatorElement.Rect.Y,
                    fixedHeaderIndicatorElement.Rect.Width,
                    fixedHeaderIndicatorElement.Rect.Height);
                // Check to make sure there is a TextUIElement, just in case the header text is
                // empty.
                if (textElement != null)
                    // Change the X of the TextUIElement's rect so that it is to the right of the
                    // FixedHeaderIndicatorUIElement.
                    textElement.Rect = new Rectangle(
                        fixedHeaderIndicatorElement.Rect.Right,
                        textElement.Rect.Y,
                        textElement.Rect.Width,
                        textElement.Rect.Height);
            bool IUIElementCreationFilter.BeforeCreateChildElements(UIElement parent)
                // Do nothing
                return false;
            #endregion
