All, I am running the AppStylist for the first time. I havn't been able to find any code samples to use in Visual Studio (2005).
I want to use (atleast at first) one of the default style libraries (such as "FlatNature.isl" or "TheBlues.isl").
I can add a appStylistRuntime, but can't seem to load a library.
What is the fastest, simplest way to load a library?
Also, where can I get technical (i.e. C#) documentation on AppStylist
dap
Calling StyleManager.Load and passing in an isl file applies to the entire application. You do not have to do it for each form.
If you want to style the inbox (non-Infragistics) controls, like the TextBox, Button, etc. then you will need to place an InboxControlStyler component on each form/usercontrol which contains any of those controls.
Thanks, I had the same question, one follow up one, do I need to set this on each form, or can I do it one for the entire application?
Thanks again for the help. Where can I get additional styles?
That was it. Had a dumb ass attack. Thanks everyone. Much appreciated
Are you sure that you've included Aero.isl as an embedded resource in the project? It should be visible in Solution Explorer, right-click on the file and make sure that the Build Action is set to "Embedded Resource". Also make sure that you have this in a Styles folder within the project.
-Matt
