1375
DisplayLayout.SaveAsXml not saving bands or columns
Is there anything that might prevent the SaveAsXml method from saving the band and column settings?
I'm calling the method at a point after InitializeLayout has run. For some grids, the SaveAsXml method saves all of the column data (position, size, etc). For some others, the exported XML file doesn't contain references to the BandsCollection, ColumnsCollection, or SortedColumnsCollection.
For the problem grid, the DataSource is bound at design time and the grid displays everything correctly when run. I tried both SaveAsXml(character) and SaveAsXml(character,PropertyCategories.All). In both cases, one grid I'm testing exports correctly, the other doesn't.
I checked at the point I'm calling the export and the grid has a bands collection (1 band) and the band has 17 columns. I've attached the two XML files. Any help would be greatly appreciated.
Jim
XmlFiles.zip
