620
Set Ultragroupbox header height
Hi
How do I set the Ultragroupbox header height ?
Thanks in advance
  • 37774
    Suggested Answer
    There is no way built into the control to increase the size of the header without increasing the size of the font.  You might be able to get this to work using a CreationFilter, but I think that you will encounter a problem with this due to the fact that the docking/anchoring logic is not really based on the UIElements, but rather on the size of the control itself.
    I was able to put together a sample that seems to handle these problems, though you will have to account for different border styles yourself.  Note that I combine both a CreationFilter as well as deriving my own class from UltraGroupBox so that I can override the DisplayRectangle property, which is used to position child controls.
    public class MyGroupBox : UltraGroupBox
        private Rectangle contentRect = Rectangle.Empty;
        public MyGroupBox()
            : base()
            this.CreationFilter = new GroupBoxCreationFilter(this);
        public Rectangle ContentRect
            get { return this.contentRect; }
            set
                if (this.contentRect == value)
                    return;
                // The CreationFilter repositions the child elements, but doesn't
                // actually update the layout.  Therefore, if we get a new content
                // rect, re-perform the layout to resize controls.
                this.contentRect = value;
                this.PerformLayout();
        public override Rectangle DisplayRectangle
            get
                if (this.contentRect != Rectangle.Empty)
                return base.DisplayRectangle;
        private class GroupBoxCreationFilter : IUIElementCreationFilter
            private const int HeaderHeight = 50;
            private MyGroupBox groupBox;
            private Rectangle lastHeaderRect = Rectangle.Empty;
            public GroupBoxCreationFilter(MyGroupBox groupBox)
                this.groupBox = groupBox;
            public void AfterCreateChildElements(UIElement parent)
            public bool BeforeCreateChildElements(UIElement parent)
                if (parent is Infragistics.Win.Misc.GroupBoxHeaderUIElement)
                    parent.Rect = new Rectangle(
                        parent.Rect.Left,
                        parent.Rect.Top,
                        parent.Rect.Width,
                        50);
                    this.lastHeaderRect = parent.Rect;
                else if (parent is Infragistics.Win.Misc.GroupBoxContentAreaUIElement)
                        parent.Rect.Left,
                        this.lastHeaderRect.Bottom,
                        parent.Rect.Width,
                        parent.Control.Size.Height - this.lastHeaderRect.Bottom);
                    Rectangle contentRect = parent.Rect;
                    contentRect.Inflate(-2, -2); // Shrink the rect so we can see the borders
                    this.groupBox.ContentRect = contentRect;
                return false;
    -Matt
