220
Scroll bar dissapears after adding a new row to grid
After we add a new row to the grid, the vertical scroll bar disappears. When we look at the filter row and click on the dropdown, we can select from there to access the rows that we cannot scroll down to. We found a temporary solution in the meantime - we found out that if we click on any of the header columns, the vertical scroll bar reappears.
Our scroll bar settings is set to automatic and the problem is reproducible.
Please help. Thanks!
  • 2501
    Suggested Answer
    Thank you for submitting your post to the Infragistics Forums.  I set up a sample application for testing by following the above description and was unable to reproduce this issue.
    I suggest that you create a small sample project which demonstrates the described behavior and  Submit an incident to Infragistics Developer Support.
    Please reference this forum post when you submit your support request.
    Thank you.
    Sincerely,
    Mike D.
    Developer Support Engineer
    Infragistics, Inc.
