2387
column sorting
Here is another question I should be able to figure out, but can not seem to find it...
How do you get the WinGrid to sort when you click on the column header?  Band[1] sorts, but Band[0] doesn't sort.  I want Band[0] to be the one that will sort, and I do NOT want Band[1] sorting.
It is my impression that this is the default behavior so I am guessing I changed something I should not have. The other possibility is the fact that I am using my own custom dataset.  The collection that is being displayed is:
class ChoiceSetList : BindingList<ChoiceSet>
Here is the designer code as it stands now:
            // dgChoiceSets
            this.dgChoiceSets.Anchor = ((System.Windows.Forms.AnchorStyles)(((System.Windows.Forms.AnchorStyles.Top | System.Windows.Forms.AnchorStyles.Left)
                        | System.Windows.Forms.AnchorStyles.Right)));
            this.dgChoiceSets.DataMember = "ChoiceSetList";
            this.dgChoiceSets.DataSource = this.choiceSetPickerBindingSource;
            this.dgChoiceSets.DisplayLayout.AutoFitStyle = Infragistics.Win.UltraWinGrid.AutoFitStyle.ResizeAllColumns;
            ultraGridColumn1.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn1.Header.VisiblePosition = 6;
            ultraGridColumn2.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn2.Header.Caption = "#";
            ultraGridColumn2.Header.VisiblePosition = 1;
            ultraGridColumn2.MaxWidth = 24;
            ultraGridColumn2.MinWidth = 24;
            ultraGridColumn2.RowLayoutColumnInfo.OriginX = 2;
            ultraGridColumn2.RowLayoutColumnInfo.OriginY = 0;
            ultraGridColumn2.RowLayoutColumnInfo.SpanX = 2;
            ultraGridColumn2.RowLayoutColumnInfo.SpanY = 2;
            ultraGridColumn2.Width = 24;
            ultraGridColumn3.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn3.Header.VisiblePosition = 0;
            ultraGridColumn3.RowLayoutColumnInfo.OriginX = 0;
            ultraGridColumn3.RowLayoutColumnInfo.OriginY = 0;
            ultraGridColumn3.RowLayoutColumnInfo.SpanX = 2;
            ultraGridColumn3.RowLayoutColumnInfo.SpanY = 2;
            ultraGridColumn3.Width = 183;
            ultraGridColumn4.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn4.Header.VisiblePosition = 2;
            ultraGridColumn4.Hidden = true;
            ultraGridColumn5.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn5.Header.VisiblePosition = 3;
            ultraGridColumn5.Hidden = true;
            ultraGridColumn6.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn6.Header.VisiblePosition = 4;
            ultraGridColumn6.Hidden = true;
            ultraGridColumn7.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn7.Header.VisiblePosition = 5;
            ultraGridColumn7.Hidden = true;
            ultraGridBand1.Columns.AddRange(new object[] {
            ultraGridColumn1,
            ultraGridColumn2,
            ultraGridColumn3,
            ultraGridColumn4,
            ultraGridColumn5,
            ultraGridColumn6,
            ultraGridColumn7});
            ultraGridColumn8.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn8.Header.VisiblePosition = 0;
            ultraGridColumn8.Width = 90;
            ultraGridColumn9.AutoCompleteMode = Infragistics.Win.AutoCompleteMode.Append;
            ultraGridColumn9.Header.VisiblePosition = 1;
            ultraGridColumn9.Width = 117;
            ultraGridBand2.Columns.AddRange(new object[] {
            ultraGridColumn8,
            ultraGridColumn9});
            ultraGridBand2.Override.AllowRowFiltering = Infragistics.Win.DefaultableBoolean.False;
            ultraGridBand2.Override.RowSelectors = Infragistics.Win.DefaultableBoolean.False;
            ultraGridBand2.Override.SelectTypeRow = Infragistics.Win.UltraWinGrid.SelectType.None;
            this.dgChoiceSets.DisplayLayout.BandsSerializer.Add(ultraGridBand1);
            this.dgChoiceSets.DisplayLayout.BandsSerializer.Add(ultraGridBand2);
            this.dgChoiceSets.DisplayLayout.CaptionVisible = Infragistics.Win.DefaultableBoolean.False;
            this.dgChoiceSets.DisplayLayout.InterBandSpacing = 0;
            this.dgChoiceSets.DisplayLayout.Override.AllowAddNew = Infragistics.Win.UltraWinGrid.AllowAddNew.No;
            this.dgChoiceSets.DisplayLayout.Override.AllowDelete = Infragistics.Win.DefaultableBoolean.False;
            this.dgChoiceSets.DisplayLayout.Override.AllowRowFiltering = Infragistics.Win.DefaultableBoolean.True;
            this.dgChoiceSets.DisplayLayout.Override.AllowUpdate = Infragistics.Win.DefaultableBoolean.False;
            this.dgChoiceSets.DisplayLayout.Override.BorderStyleCell = Infragistics.Win.UIElementBorderStyle.RaisedSoft;
            this.dgChoiceSets.DisplayLayout.Override.BorderStyleRow = Infragistics.Win.UIElementBorderStyle.None;
            this.dgChoiceSets.DisplayLayout.Override.CellClickAction = Infragistics.Win.UltraWinGrid.CellClickAction.RowSelect;
            appearance2.BorderColor = System.Drawing.Color.White;
            this.dgChoiceSets.DisplayLayout.Override.RowAppearance = appearance2;
            this.dgChoiceSets.DisplayLayout.Override.RowSelectors = Infragistics.Win.DefaultableBoolean.True;
            this.dgChoiceSets.DisplayLayout.Override.WrapHeaderText = Infragistics.Win.DefaultableBoolean.False;
            this.dgChoiceSets.DisplayLayout.RowConnectorStyle = Infragistics.Win.UltraWinGrid.RowConnectorStyle.None;
            this.dgChoiceSets.Font = new System.Drawing.Font("Microsoft Sans Serif", 8.25F, System.Drawing.FontStyle.Regular, System.Drawing.GraphicsUnit.Point, ((byte)(0)));
            this.dgChoiceSets.Location = new System.Drawing.Point(12, 33);
            this.dgChoiceSets.Name = "dgChoiceSets";
            this.dgChoiceSets.Size = new System.Drawing.Size(247, 379);
            this.dgChoiceSets.TabIndex = 0;
            this.dgChoiceSets.InitializeRow += new Infragistics.Win.UltraWinGrid.InitializeRowEventHandler(this.dgChoiceSets_InitializeRow);
            this.dgChoiceSets.InitializeLayout += new Infragistics.Win.UltraWinGrid.InitializeLayoutEventHandler(this.dgChoiceSets_InitializeLayout);
            this.dgChoiceSets.AfterSelectChange += new Infragistics.Win.UltraWinGrid.AfterSelectChangeEventHandler(this.dgChoiceSets_AfterSelectChange);
