680
Exception thrown when adding DockableControlPane to DockAreaPane
I am using an Infragistics docking manager in my application. In this application I have support for saving layouts and loading them again during runtime. The problem I am having is when I'm disposing an old layout. Below follows a code snippet of what happens when the user has disposed an old layout and selected to create a new one. LayoutWorkspace is a class that inherits from DockableControlPane.
            LayoutWorkspace layoutWorkspace = GenerateWorkspace();
            layoutWorkspace.RootWorkItem = RootWorkItem;
            layoutWorkspace.WorkspacePanel.Click += new EventHandler(OnLayoutWorkspace_Click);
            layoutWorkspace.SetName(workspaceName);
            layoutWorkspace.FlyoutSize = m_MainDockingArea.ActualSize;
            layoutWorkspace.WorkspacePanel.BackColor = Color.White;
            if (!m_DockingManager.DockAreas.Contains(m_MainDockingArea))
                m_MainDockingArea = new DockAreaPane(DockedLocation.DockedLeft);
                m_DockingManager.DockAreas.Add(m_MainDockingArea);
            m_MainDockingArea.Panes.Add(layoutWorkspace);
When this code executes, the if block runs which means that m_MainDockingArea is newly created. My problem is that the last row: "m_MainDockingArea.Panes.Add(layoutWorkspace);" throws an exception saying that I'm trying to use a disposed object. The object mentioned is an old window form that was part of the OLD DockAreaPane. Do you have any idea why this might be happening? I should also mention that it only happens during some special constalation of windows ie. most layouts I have are disposed perfectly fine. I should also mention that we are using v8.2 of infragistic WinForms dlls.
