i want draw a linechart, and i set thedatasource
UltraChart1.DataSource = dtgrafico (where dtgrafico is an integer datatable)
after i set the datamember to the row
UltraChart1.DataMember = dtgrafico.Rows(0).ToString
Ok the chart is perfect, i see the legend, but i read row0, row1,row2....
How can change the names of the rows in the legend? i try with ultrachart1.series.label with errors
thanks, its work!!
you can either add a string column to your datasource, or use the UltraChart1.Data.SetRowLabels(string[]) method.
