We have a requirement for an administrator in a remote location to specify the isl file in our multi-tiered application.
So the admin may change the style and all the applications should use this new isl even though they may be in a different country in our Enterprise App.
We therefore need server-side styles - my question is has anyone done this and/or is there a recommended model for this.
My very quick default solution would be to stream the isl using WCF or web service at client startup and overwrite the local ISL from the file generated. We can't use a network UNC for the isl file name.
If anyone has done this or something similar we'd be grateful for any comments.
Kenny
I am just checking about the progress of this issue. Let me know If you need any further assistance on this issue?
Hello ,
Other thing what you could do is to save the isl in database on your server, and when the user runs the application on his side, connect to the server in order to retrieve the isl (stream of the isl) from the database and to use Load method of the StileManaget with stream parameter. http://help.infragistics.com/Help/NetAdvantage/WinForms/2011.1/CLR2.0/html/Infragistics2.Win.v11.1~Infragistics.Win.AppStyling.StyleManager~Load.html
