630
Problem with UltraCombo and Moving to Next Control on Form
Recently, I had a request from a user that when they selected a row in an UltraCombo control the focus would automatically move to the next control on the form. Here is the code I am using:
Private Sub ucboDataClassCode_RowSelected(ByVal sender As System.Object, ByVal e As Infragistics.Win.UltraWinGrid.RowSelectedEventArgs) Handles ucboDataClassCode.RowSelected
    Try
        Me.SelectNextControl(Me.ActiveControl, True, True, True, True)
    Catch ex As Exception
        MessageBox.Show(ex.Message & vbCrLf & vbCrLf & ex.StackTrace, Me.Text, MessageBoxButtons.OK, MessageBoxIcon.Error)
    End Try
End Sub
But after I added this code we noticed that the control was no longer updating the row/column in the datatable and consequently the data was not being updated to the table in SQL Server on the save.
So I add this line of code to the event with no change, the control was still not updating the datatable it was bound to.
Me.ucboDataClassCode.UpdateData()
What can I do to fix this?
  • 469350
    Suggested Answer
    Hi James,
    I can't be sure about this, but my best guess is that the BindingManager is not updating the underlying data source because the control is losing focus before the Value is updated. I have noticed cases in the past where the BindingManager does not response to the setting of a value when the control is not currently active. I guess is does this on the assumption that you only want to pick up changes made by the user.
    If that's the case, then one way you might be able to get around it is to move the code from the RowSelected event into a separate method. Then, in the RowSelected event, you would call that method using a BeginInvoke instead of calling the method directly. This should create a delay before the code executes so that the Value of the control is updated before the SelectNextControl call is executed.
