589
Column - Setting the bar width
Hi
I am using the column chart to display the graph and the bar width depends on the number of  rows in the data table.
For example, if the datatable contains only two rows, then the two bar appears in the chart and each bar occupies 50% of the chart area. If there are four rows, then each bar occupies 25% of the chart area.
I would like to use a constant bar width instead of variant width based on the number of records. Can I set the bar width?. Can you show me an example?
Regards, Karthik
