Is there any way to make Infragistics.Win.UltraWinGrid.UltraGrid behave more like Excel when it clips cell text because the text is too long for the cell? The UltraGrid chops the text and appends ellipses. Excel just chops the text.
Consider the string "123456789". If the UltraGridCell only has enough real estate to show 4 characters, it will show "1234..." (or possibly "123..." since the ellipse takes up some space). I need it to show "1234" (no ellipse).
It looks like on the web grid there might be a setting to control it: this.UltraWebGrid1.DisplayLayout.RowStyleDefault.TextOverflow = TextOverflow.Ellipsis;
this
Is there a similar setting for UltraWinGrid.UltraGrid?
Yes there is such a property: TextTrimming you can find it in CellAppearance.
And in your particular case you can set it like so:
ultraGrid1.DisplayLayouts.Bands[0].Column[0].CellAppearance.TextTrimming = TextTrimming.None;
Hope this helps.
Regards Petar.
