Hi.
I have a series of data that I am plotting as either a column chart of Line Chart depending on user preference. If it is a ColumnChart I have to set the SwapRowsAndColumns but other than that the data displays fine.
Based on user input I want to be able to hide a series so when the user picks the series to be hidden I am finding the series within ultraChart.Series and then setting Visible on that series to be False. I then InvalidateAllLayers and call refresh on the chart. When I am using the LineChart this works as expected but when I am viewing the ColumnChart nothing happens. I am assuming that I am missing something simple but I cant see from teh docs.
Do I need to do something else when using a ColumnChart? I cannot use ultrachart.Data.IncludeColumn() because ultrachart.Data is not set because I am using a Series Collection.
Code Below to set visibel. Works fine with Line Chart but not with Column.
foreach (NumericSeries n in ultraChart1.Series)
n.Visible = streamDisplay[n.Label] ?
true : false;
ultraChart1.InvalidateLayers();
ultraChart1.Refresh();
Thks
Dan
rebuilt using 8.1.20081.1000 -- still works fine
I cannot try this test project as it seems to be built against 8.3 and I am using 8.1. Do you have a test project that works for 8.1. I tried building the other project against 8.1 and I couldnt get it to work.
Tks
i tested the behavior of Series.Visible with a column chart and it seemed fine. attached is my sample project. does this work for you?
i tested the behavior of Series.Visible with Column charts, and it worked as expected. attached is the project i used. does this work for you?
Any info on this? I assume I am missing something really obvious or that this isnt supposed to work with ColumnChart or something but I cant figure it out from the docs and it works fine on a LineChart.
I am using Netadvantage for .Net 8.1.
