Using VS2008 running on XP OS with the following controls:
Runtime version: v2.0.50727
Version: 9.1.20091.1000
I have an UltraComboEditor positioned in line with the UltraTextEditor. The look ok at design time, both have the same font type and size, and both have the same Size.Height property.
However at run time the combo box switches to a Size.Height = 22 and creates a bad visual experience for User.
I remember that the Microsoft equivalent control had a simillar problem and had to write some code to overwrite it. Did you guys fixed in your UltraComboEditor? Apparently not. Is any way I can revert the hight of the combo box so it matches the size of the other text boxes?
Thanks.
Thanks Matt for your clarifications.
We here, were under impression that this mechanism works like "last one wins" scheme, so you can finely tune the apperance at the control instance itself, when needed of course.
Considering "Application and then Control" situation, since the system does not *overwrite*, it remains several possibilities if you want to change something already set in the AppStyler:
1. Set "UseAppStyling" to False for the control instance and redo manually the whole styling using the "Properties" tab;
2. Write code in Initialize or Load event (for example) to overwrite those properties, set in Application Styler, you need to change;
3. Create a separate Style Library and and pass it to the control instance in the "StyleLibraryName" property.
Am I right on these assumptions?
"Application Then Control" gives priority to the ISL file over the control-specific settings. When resolving properties or appearances, the values are never *overwritten*; rather, only properties that haven't already been set are resolved. This means that whenever using the "Application Then Control" resolution order, the Control will only resolve properties that the ISL didn't already have a setting for.
-Matt
You are right. I was not doing any special settings in code, however the setting was overwritten by the setting in the "isl" file, which was not properly set.
I have a question about the "Resolution order": when you guys say "Application Then Control" which one has the most priority?
Do you mean: <<set with the values in ISL and then overwrite with the values from the control's properties>>, or the other way arround?
-Octavian
I can't reproduce this issue on my machine. What font and size are you using on your controls? Are you setting any other properties that may be relevant to the presentation?
