75
Accessing grid columns in same sequence in which they are visible
Hi, I need to access columns of infragistics ultragrid in same sequence in which they are being displayed in grid. If i can get the index of column in same sequence as they are visible on grid, i can fix my issues. Thanks in advance. Lalit
  • 12773
    Hello ,
    You can look at this tread, here is a information how to access the visible position of the columns:
    http://forums.infragistics.com/forums/p/25572/93767.aspx#93767
    I hope this helps.
    Sincerely,
    Dimitrina Gineva
    Developer Support Engineer
    Infragistics, Inc.
  • 469350
    Suggested Answer
    It's rather complicated to try to do this using VisiblePosition. Here's a better way:
                UltraGridColumn column = this.ultraGrid1.DisplayLayout.Bands[0].GetFirstVisibleCol(this.ultraGrid1.ActiveColScrollRegion, true);
                while (column != null)
                    Debug.WriteLine(column.Header.Caption);
                    column = column.GetRelatedVisibleColumn(VisibleRelation.Next);
  • 815
    You can get this value from the .Header.VisiblePosition property from the column object.  This controls the order that columns are displayed in the grid.
