449
Can I put Ribbon in a View instead of Shell, using CAB
I am using Ribbon with a CAB application. We want the Ribbon in a View(not in the shell). but it comes out like in the attached file. with 2 form heads. We want the Ribbon's application menu and not the shells. Is a way to do this? If I put the Ribbon in shell, it comes out fine. but we don't want all toolbar handling in the ShellForm.cs. That is too much code there.
Do u have an good example to look for this? All CAB & Ribbon examples shows how to register Ribbon as UIExtension, but how to handle the clicks?
